esploso senza frecce
  • Thread starter Thread starter Dador
Dador
Good morning to all.......:biggrin:
I would like to eliminate the arrow pointer from the explosions!! !
I mean, in creating the automatic ball, I don't find the setting to eliminate the " terminal arrow" : where should I look?!?
thank you so much for the availability now!!!!
select the ball and then disable "add a director to a ball".
No, no, no, no, no.
the line that connects the ball to the piece is fine, but without " terminal arrow" .
in the annex we see the correct example with the piece "26"
until today I used the automatic ball that appeared to me as for the piece "25". Now I'd like to automatically ball like "26"!
for now I have only succeeded in "manual" to replace the arrow with the point and give it the dimension equal to zero!
No, no, no, no, no.
select the ball, go to property (it is the command above the arrow I indicated before), go to "text and reference" and to the voice "terminator" choose
"empty"
Thank you very much!!!! :finger:
How do I do to save it in the settings so that the ball is already "empty"?
