esportare da allplan ad autocad
  • Thread starter Thread starter petitgio85
petitgio85
Hello.
I need help from someone accustomed to working with these two programs! !
I created an all-plan model for an architectural examination, only that I miss all the outside and there are some things to retouch, like polygons with plans that combine.
I would like to import the model in autocad, since I am used to use the 3d and I find some commands faster, but when I did "export" and I opened the model in autocad I saw that the parallelepipeds and objects are not modified by the tools of "edit" solids, for example I can not join the solids and perform the offset of the faces.
is there any way to export the model to be able to work on it? ?
