Esportare grafica 2d_pdf
  • Thread starter Thread starter My_Key
My_Key
hello to all
I have to export a sketchup image, and I would like to do it via pdf. in the panel settings of the export 2d graphic command activates the check on show profiles, match screen display both auto width and auto lenght, extend edges, and I give it ok. when I open the pdf created but 'the objects lose the textures (in this case I applied the fences texture, which also contains the alpha channel to discount the holes).
Could someone tell me where I'm wrong? I could also export as jpeg image and then I wouldn't have the problem, but the image files are a bit heavy and long to generate.
use windows xp, with on 8 pro.
