pizzaf40
Hello, everyone.
I'm doing some composite simulations. Now I'm treating modeling a tube with the volumes of the individual layers, so not as layered. the problem is that, having elastic orthotropic characteristics, it is necessary that x is the axial direction for each element, z is the radial and y the tangential (on all elements).
to solve the problem I created a cylindrical system, but I managed to create it only with the axial z. therefore not respect the elastic characteristics.
I then tried to create a Cartesian with x in axial direction, but so I obviously got the z and y that do not respect the radial and tangential directions...and I couldn't find how to reorient them.
(I can't change the input elastic data because it tells me that the system matrix is no longer defined positive, so the x-inversion in material data can't do it)
Can someone recommend me how to do it?
the elements with solid186 in ansys 12.1, the cylinder is composed of 9 concentric cylinders, the thicknesses of each in general are different.
