lucaaa
First I apologize for my English. I'll explain my problem. I'm trying to simulate a fluid bed reactor with fluent. I used the multi-phase eulerian-eulerian model and so far there were no problems. But now I was interested in evaluating particle trajectories within the reactor and then using the dpm model. in particular from the guide I read that you can use the eulerian model including ddpm. when I go to set up my problem with these parameters, launch the simulation and find immediately a divergence. How can I do to simulate my model? I hope I've been clear in the explanation. I also tried to do so:
-I launch the simulation without introducing any particle so as to have a convergent solution;
-I insert the particle inside the reactor by selecting the dpm from the model menu.
is it correct?? I thank you in advance for the answer.
