explosion bubble
  • Thread starter Thread starter SIMONE02
SIMONE02
Good morning.
I have a problem with the bubble on an explosion of a saved view.
the director does not start from the component but remains detached from the same, besides selecting the component does not always recognize it.
Can anyone help me? Thank you.
try to explain yourself better, perhaps with the help of images, otherwise it is difficult to understand what might be the prboble... .
I don't know if it's a real solution. .
However I noticed that it is not possible to place the bubble on an explosive saved in any location (e.g. view1 in the attached image) if not updating standard views.
I mean that once I rotated the explosive at will, to allow the bubble in the table I owe, in the orientation menu I attached, click on the icon "update standard views" and select under a standard orientation of choice.
in practice you can insert a bubble at the view of the table only if you recognize it as standard views.
This is my solution but it is not said to be the right one.
But, strange. I did a quick test and it works at every rotation without updating anything.
later maybe I try to make a video so you see the steps I do and we comment them
Here's the video.
Perhaps the procedure you have done is different and consequently the result.
I'm curious because even if the explosives use them little to understand the malfunction of an event could come in handy in the future
I hoped I'd be given an answer to understand and learn something, but it doesn't work like that.
