explosion of a connected revit model
  • Thread starter Thread starter Sandra_ME30
moreorless 18.12.15 17:09
Thank you so much tristan, very clear explanation.
but what can depend on the fact that it is not between 3d views to choose any view among the new ones I created? gives me as the only 3d view available this: {3d}, which then is the default assonometric view of revit. I then created some others, rename them, so I no longer have a view with a similar name, and if I try to rename one in this way, revit tells me that I can not use certain symbols (including p. graffa). Anyway, do you think it depends on this? How could I solve this?
Thank you!
sadan 18.12.15 20:58
but in the linked file is the view 3d exploded? if there is must appear in the list.. .
moreorless 18.12.15 22:31
in the file I created various 3d views to frame the different objects present in the file. Having regard to a 3d view, within graphic substitution > revit links > object name imported from host view > connected view: At this point I don't even find one of the 3d views I have previously created.
Annex 42689
sadan 19.12.15 10:50
but did 3d views create them in the host file? or in the linked file?
