export: artlantis-->3d max
paga92
Hello, everyone.
I would like to export a model that I texturized with atlantis and where I inserted some objects in 3d max. I have to do it because it has to be completed by a user who uses 3d max. I don't want to miss the textures and objects.
I tried to export to .skj and .obj but it does not save me textures and objects. on the contrary sometimes it gives me own error in export!
I didn't understand why if I get out of archicad in .skj saves everything (textures and objects) that are visible in 3d max while if I do the same thing in atlas no!.
so the alternatives are. There is a method I do not know to export to 3d max. or I mistake something in saving in .skj
If there was a way to return to archicad after I texturized in atlantis from I could save them in .skj, but I am not able to do so.
other thing.. I'm here. can you create lamps with your own photometric light (file .ies) in atlantis? like objects that are present standard in the library for example.
s.o.s!!!... help me!!! is the 4 question I ask! at least one answer please!! !
