export bom of a group in excell
  • Thread starter Thread starter PetrusCad
PetrusCad
Hello everyone
please ask for instruction to produce a .txt file or other with data of a bom of a analyzed group
thanks in any case
Hello everyone
thanks in any case
but do you have model managers or use "base" modeling? Unfortunately without model manager reports are very primitive... .
Good day
thanks always for your attention.
I am using osd modeling 2006 without model manager, otherwise I could send to the place of annotation with the excell, usually with cocreate and mm this operation succeeds.
If you knew some expedient, I would be grateful to you, as I am grateful for this correspondence.
Good
pietro
Good day
Good
pietro
I was trying with v17 but I can't. on the American forum I found this link:
http://www.cocreateusers.org/forum/showthread.php?t=5244&highlight=export_tablebut I did not do tests ( fortunately I have the license mm).
you'll realize that with lisp I have no hope. . .
I dragged the education without the part ---> .... so you project the table (as an alternative to analysis ) but nothing else
Maybe I have to paste the instruction piece on the user bar? Or do I have lourdes? ?
desperate lispmen... .
I tried it and it works.
Do this:
1) copy the instruction text to notepad, and then save the file in *.lsp format
2) put in the board and do the analysis
3) charge the lisp
4) now in the tool menu find the item "Export table", run it
5) opens the menu to dx, choose a table template, the file name and then give the ok
Do this:
3) charge the lisp
I just tried and it works great.
these expedients are reason for small omnipotence
How can I return for your patience?
petrus I'm glad you found help with our expert hunter!
I think I understand you're not Italian, where are you from? If you find yourself better you can write in English, it will be a pleasure for us to help you!
the lsp file in which folder should I copy it?
usually the lisp files just upload them as a normal file and then the command appears in tools, but be careful that many lisp that worked until version 17 from 18 on then need a string to be added.
Excuse me, but I'm not very experienced. . .
how do you upload the lisp files?
simply open the charge icon and in the menu where you can choose the file type: pkg, bdl, mi etc etc etc. choose "sorgente lisp" extension lsp or lisp
