Dave1978
Good morning they are greedy,
and work on behalf of a company as a technical designer. It's the first time I've been in a forum and I hope to follow the right procedures... If it weren't for me to listen.
always at the company for which I work I have created all the blocks in both 2d and 3d with within them the attributes that identify the respective code in order to be able to extrapolate its separate ones by extracting data on a excel sheet. Starting from this premise I ask you politely if it was possible to create a quick selection button that allows with a single clik to extract in a excel sheet the distinct materials from autocad without having to remake all the process of data extraction (not that it is so long, but I wanted to automate it ) with the possibility of selecting objects in the model space.
I temporarily extract the data in excel using a dxe model, but as mentioned, I wanted to automate it by creating a button. I have also tried to create this by using vba but not being hardware in the matter therefore I do not know if I have taken the right path
autocad use 2013
a greeting hoping to be clear
autocad use 2013
