export dxf topsolid 6.11 64 bit
  • Thread starter Thread starter c.buzzetti
c.buzzetti
Hello, everyone.
recently passed to the 64-bit version of topsolid 6.11. I found a lot of difficulties in exporting the dxf format. I explain better: in the 32-bit version I had available options in export, while in this there are no. Did someone find the same problem? How did you solve it?
In fact, in the 32-bit version there are currently 2 versions of dwg/dxf one of the older version 6.7 and one of the new version, 64-bit topsolid being more recent only owns the latest version, but with the last patches the export problems have been solved, which results me if you encounter problems let me know what you do, that if I can help you velentieri.
Hello stefano,
Thank you for the answer so fast.
My problem is that I have to send to our dxf cam program without composite. the 32-bit version allowed me to set the conversion with flags, while in the 64-bit version I can't find this opportunity.
Is there any other system?
you have tried cone the dxf configurations that you find in sheet metal-interfaces with delem or cybelec or in the sheet-management development-congests development and export this to dxf.
Let me know.
I tried in both ways but the result doesn't change. exported dxf are composites.
