export files dxf/dwg da solidworks
  • Thread starter Thread starter jhonny890
jhonny890
Good morning to all,
I am trying to automate the export of parts (lamiera) by turning a macro that automatically extracts all files from a set.
the macro I managed to generate it, but the question I wanted to ask is the following:
is it possible to insert in the file that is exported in .dxf format also the maximum quotas and the reference of the code reported in the file name?
this operation I need because then once you create all the dxfs I go to join them in a single file of autocad divided by thickness, so I need all the files exported by solid, they already go out with the maximum quotas (axb) and with the reference of the identification code.
I attach an example that I have created by hand through autocad where you can see the final result that I need to get automatically.
Can you help me?
Thank you very much
@jhonny890, perhaps if you attach the macro and an example file who has experience in this matter should not be able to reinvent, arbitrarily, already existing material starting from a miserable image
