export instance family table step with creo distributed batch
  • Thread starter Thread starter calacc
calacc
Good morning, everyone!
I need to export in step format of a part model that contains various instances of family table.
to do this I am using just creo distributed batch and I would like that to every instance he created me a file in corresponding step. I mean if I have a generic and n variables I would like to output n file in stp.
in creo distributed batch select the instances in the field "objects" but known with disappointment that once the group is started, it stops only after 2 seconds.
Note that if I select other prt files like the generic (without family table though) I regularly export them to block.
do you know if there is a way to succeed, that it is obviously not to open and export files individually?
Thank you very much
