marcopj84
hello to all and thanks in advance of attention, here is the problem: I’m working on a project with my old and trusted autocad 2007, continually swapping dwg files with a colleague who works in teams on autocad 2011 (of course set to save in 2007 format). until now everything well but yesterday we started to use different types of lines from the common continuous line, in particular lines zig zag and insulating. when I open the file saved from cad 2011 inside my cad 2007 a message tells me that:
this application found objects of a new verse in the design. Some ocmands may not work. saves the design from the original application nol format autocad 2000/2004/2007 or as the aec objects exploded, or with the activated proxygraphic and attach it as a kref in order to use it as a background.
as I have already repeated that the file is in 2007 format and that I do not have the pallida idea what the aec or proxygraphic objects are the symptom is: the zig zag and insulating lines appear scaled by a factor about 0.05 (empirically speaking). You know, if we can't let the two cads communicate, we can't work.
How is this possible? ?
if there were some help I also tell you that initially I created a dwg from my cad2007 with the above-mentioned line types that my colleague opened and used to paste the properties to other lines as, novello of the 2011 version, could not find the window for line management.
thanks to the attention
m
m
