emanuele ranucci
thank you in advance for your availability.
I have the need to export objects (travelling and roads) made with the civil modeler to revit. I'm using the 'extreme modeler' command in a new file that then matters on revit via 'importa cad', I would have two questions.
- how can I make the imported file coincide (same xyz position) on revit and civil 3d?
- for necessity of future rendering and application materials I would need the imported instance to be differentiated, for example the rails of the railway differ from the massive, how can it be done?
currently the imported file appears as a unique entity to which it is not possible to assign a material from revit
