drake
Hello everyone, I just realized this problem I had never met before.
Usually when I decide to give the 3d model of a structure I carry it in .sat and then the amount in autocad and I create the dwg 3d.
I've always done it and I've never seen any problem. the last time I did it to send it to the designer who develops the executives for the company that will realize it, he tells me that he finds inconsistencies in the model. So I realized that the dwg was not correct.
the model in question contains hidden elements.
before exporting load the model in fixed mode, therefore correct with all the elements that must be visible and hidden right. I do the save by name and be answering you or not to the question that makes you sw before starting export
the result is that the components are all visible!
I've been doing this for several years, but I've never seen this.
Is that what you want?
the result is that the components are all visible!I've been doing this for several years, but I've never seen this.
