export scale boards
  • Thread starter Thread starter Danig
Danig
I have to export the various prepared boards (plants, brochures, sections) in a format and then go to dress them up with photoshop.
Can someone tell me how to export them to scale?
I need the boards at 50, but when I save the tiff (for example), then in ps it does not have the size it should have. .
I select the table and impose 100% of the size, where am I wrong?
to print on file, use pdf creator, create the revit cartiglio, complete the table with the scale you want to represent. use pdfcreator as a printer, select the size of the sheet equal to that of the paper. zoom at 100x100, center print and mold all in pdf in the correct scale.
if you want there is also the dwf format.
in the hurry I had to use another pdf printer, the result is not bad for plants, prospects and sections. if instead I carry a 3d view is of very low quality. .
