export settings in dwg from revit
  • Thread starter Thread starter a.zin
a.zin
hello to all, I have demand regarding export revit tables in dwg format.
I'm setting the export settings but I can't solve a problem: if I have seen with associated different view patterns it is possible somehow to translate it into export? I make a practical example, table with septic carpenters, I have views of plant and prospect of each single sett and a key plan with different view model that highlights me in red the sects. there is no way to bring out this difference in dwg because I can only set the category walls in general (view and section). solutions? I hope I'm explained. .
I'm afraid not. I do not understand that the graphical replacements are exportable to dwg...
...and insteadyou can try to export by configuring replacements on a new layer:
export layer options​
to export layer options, specify how revit elements with specific graphical replacements of the view will be mapped to cad layers.
(graphic properties of revit elements, such as color, line thickness and line style, are defined in styles of objects of the categories to which the elements belong, but such definitions can be The opposition for a selected item in a specific view).
  • export properties category bylayer and byentity replacements. revit elements with specific graphical replacements for a given view retain such replacements in the cad application, but will be placed on the same cad layer of the other entities in the same category of revit.
  • export all properties bylayer but not replacements. the specific graphical replacements of the view will be ignored in the cad application. all the elements of revit will be exported on the same layer of the other entities in the same category of revit. so that all entities display the visual properties defined according to the respective layers, this option allows to generate a lower layer number and to control the exported dwg/dwf file according to the layer.
  • export all bylayer properties and create new layers for replacements. a revit element with specific visual graphics is placed on a cad layer. this option allows by-layer control on exported dwg/dxf file and graphic intent is maintained. However, it involves increasing the number of layers in the exported dwg file.
