export the dxf floor of a sheet
  • Thread starter Thread starter benny79
benny79
I'm using the 2016 version of inventor in sheet metal environment, but I can't save the dxf plan directly as when I go to "Save with Name" I only have the chance to save the .dwg file!
Can someone help me or know if it is possible to do it?
you do not have to save the flat model in dxf, although it is developed, it is always a solid with its thickness.
you have to right-click on the flat face, from the drop-down window opening choose " export face with name " and here you can save in dxf
Thanks for the answer, then I actually managed to cuff out a little bit.
I know there are plugs in to automatically save the dxfs of several developed parts and even a whole set, if you know anything about it?
