export to step
  • Thread starter Thread starter Lorenz75
Lorenz75
My client uses rhino and did a study in 3d that must pass me to make the industrialization of details and tables 2d (in creo ).
the problem is that when I pass the step of the axieme (exported with the set step 214 automotive design), importing it from clay into the tree I do not have all the solids that make up the axieme.
of some objects yes, while of others (actually most) I have a single surface containing everything... So I can't work on it.
This happens only with steps and iges exported from rhino, with files from other cad does not happen.
I also tried to open the file with other cads, but the problem persists.
is there any settling to be set up during export?
Thank you so much!
Lorenzo
I would say that the problem is how it was shaped in rhino.
It's a "good mouth" software, sometimes those who use it don't look much for the subtle and create unclosed solids, corrupt surfaces etc.
Then so much I'm there... of who has to work with another cad.
It is not said that it has been drawn incorrectly, sometimes it is also a problem of export settings, this thing I am noticing also I that I find myself passing some files to other operators who use different cads that opening them find these issues......
