spodus
Good morning to all,
I am a student enrolled in the last year of mechanical engineering at the Milan Polytechnic. for my thesis work I am using openfoam software, an opensource cfd. the geometry object of investigation is the recent etr1000 (trade name arrowrossa 1000) that I was supplied as catia assembly. having to provide geometry to openfoam, and reading the latter the stl format, I informed myself about the conversion of catia file to stl and I read that it is possible to convert in stl format only the part type files and not the product type files. do you confirm that you cannot export a product file in stl format?
I am aware that I can easily convert a product file into part with the command ''generate part from product' but unfortunately when I try this solution with the assembly of the train fails to convert everything and it gives me error. it would therefore be preferable if there was the opportunity to directly convert the product to stl without passing for conversion to part.
thank you so much for your attention and good day!
