export together as solid full
  • Thread starter Thread starter Shotfree
I'm sorry, but I'm a little busy with work, thankfully. why did you choose solid faceted as typology? you have to use the geom copy method. If I can get you a video from allgarten
thank you, do with the utmost calm so much for now I manually selected the missing components, a workmanship but I came out, after I try again with copy surfaces, but I need a solid full.
Good evening to all, is there any news? other answers? Forgive me for breaking up, but every time a new model comes to be converted is a cross! :
Thanks again
Good afternoon to all, % 1 @freexf Do you have any news? I also add another thing, for some familytable models based on the creo height fills all the cavities inside or not. Pretend to have a grid made of pipes, for certain heights the tubes are completely filled (and the model is as we need), for others instead the tube remains empty (so they are evincible thicknesses (it is not good).
I hope you understand the problem.
