export together with connected parts
  • Thread starter Thread starter robby hg
robby hg
I searched in the forums present, but I was unable to find an answer to my need.
I wonder if with nx4 you can export a complete set with all its native parts and copy it to a single folder without using external tools.
I have no additional forms available except those in the basic license.
For those who use solid edge, I wonder if there was anything like revision manager?
thanks in advance to all those who can help me
Hello, there is no command like the revision manager of if.
the possibilities you have in nx native are:
1) download a tool called ugzipc, free program that adds in nx a command that zips a complete axieme.
2) make you a "clone" of the axieme, in this case you can give suffixes/prefixes to all components and place them on a single folder.
3) use the command "ugpc.exe" from the nx command window, this will print the list of components contained in the axieme with the path, if you redirect the command to a text file (and you don't have a large number of components) then you can create a batch file that will copy the components where you want.
This is what comes to my mind.
I hope you can help.
Bye.
I tried to use ugzipc with nx4 following the installation procedure (I copied the folders and added the system variables) but once launched nx in modeling assembly under file -> export -> of zip assembly there is no trace .... (laughing)
At the moment we use nx7.5 64bit and actually I also had some problems in the operation of ugzip for this version.
in my case were problems mostly related to malfunction in the sense that it did not "recover" all files of the axieme but only some randomly.
on the forum of siemens we discussed it and they gave me a new dll of the application that at the moment works well as the previous ones.
1: I have not tested the 32 bit version
2: I have not tested nx8
3: I whisper a jump on the forum siemens and search for the messages of rob cohon "customizing" or "customization"
