Arduinoasd
Good morning to all, I looked through the various discussions and around the net but I did not find what I look for.
I would like to make on a cylinder with a diameter of 114 mm and with a thickness of 3 mm a skull (for my personal taste and not for work) using a lser tubes.
the procedure I have followed so far is as follows:
searched for the image I liked (Raster format) and converted into vector image so that you can save it in .dxf to open it from autocad and continue to work on it.
in autocad I arranged it so as to create joints where I want the material to remain and where there are, in fact, the material once the laser cut passes will have to fall.
the problem is created when, I want to import the .dxf file on solidworks to apply it on the cylinder and create the extruded cuts so as to have the "finished" piece to then be able to import it into the cam language and make it work to the machine. I don't know how to import this file and make cuts, with the decal function sticks the image above and doesn't make me work.
perhaps mistaken way of approaching or there are other methods to do this kind of work.
thank you very much to those who will answer me
