Alessandro_
Good evening,
I created a dynamic block with parametric constraints, inside the block there is a polylinea and a dash attached to it.
now replicated this block and modified the cyanide measures, I would like to have the area of polylinea or hold for each block.
Is there a way?
I tried to put the area as a data field in the attribute content, but it doesn't work.
for now I have solved by dividing this polyline into triangles whose sides have a parameter to which I gave a name (a,b,c... )
then in the design I put in the attribute of the block the formula of eulero, returned the correct area I replicated the block and modified the measures the area is returned correctly for each block
Is there a simpler way?
alessandro
Is there a way?
alessandro
