extract parts from multibody while maintaining machining
graziano-g
Hi, maybe I will have happened but now I don't remember, if you can do, how can you do... .
I shaped a multibody keeping separate the various bodies with the new solid function.
each new solid therefore has its specific processing, the only thing in common among some solids are some plans.
step to the management board and select creates components, select all components then imposed name and model of the axieme, then select the model for the individual parts and check them a name, is generated the axieme within which there are the various parts.
If I open a part, however, I do not find the series of work that has generated it.
I demand too much or am I wrong?
when creating independent parts from a multibody only geometries are generated without processing, in fact it becomes a derivative of the original. can be incorporated into the sketches, working geometries, parameters or other part but not individual processing.
if you have to make changes you do directly in the multicopro.
also because otherwise, it would not make much sense the multibody
hi to maintain the work I follow a road not really comfortable but functional, i.e., except a file for each component and then I keep one and I delete the others, but I believe and hope there is a more functional procedure
to keep the work I follow...
It's the same thing I do, fortunately not often.
who asks me the multibody, generally, does not ask me the semi-finished.
if the semi-finished are necessary, I do not make a multibody.
there are pros and cons, in addition to the impositions of customers.
I use multibody very often especially when I make hoppers composed of different sheets and with complex geometries.
finished the multibody with all the solids divided I make a set with the same name of the multicopro, and I insert it into the axieme by binding the origins.
I put in "hidden" the multi-copro part and generate all the components inside the axieme.
all the parts generate the bonds all with their origins to the origin of the assemblies as they are the same.
if I have to change something obviously I do it from the multibody and update all the respective components.
