extract the value of the centerpiece
  • Thread starter Thread starter joe
joe
Hello, I look for a lisp routine that can extract the value of the centerpiece, of any object, found by the massprop command.
inside the lisp you find the centerid command; returns a list with the x y z coordinates of the central point and also the weight command with the text "the weight is kg"
excuse but the following code, which would serve me to detect the center of a solid, gives me as a result on the command line: 0.0.0.0.0
(defun c:ba (/ fr x y z txt peso nomefile)
(setq filename "c:/users/salvator/massprop.mpr")
(setq ent (car (entsel "\nselect solid: ")
(command "_massprop" ent "_y" filename)
(if (/= (findfile nomefile) nil)
(progn)
(setq fr)
(repeat 9)
(setq txt (read-line fr)
(setq x (atof) (substr txt 26))
(setq y (atof) (substr txt 26))
(setq z) (substr txt 26))
(close fr)
(vl-file-delete filename)
(list x y z)
(alert "problem with file creation")
