extruded without overlap
  • Thread starter Thread starter joejack
joejack
can you use the extruded function es on a polygon of an object without going to occupy an already occupied space? must do extrusion only where space is free without other objects or part of the object itself
can you post an image to explain better?
Sure. extrusion, create a copy of the solids that intersect and then subtract them from your polygon. But you should see your case specifically. post part of model or images
