So the cover on the wall as we put it?I'm afraid you're messing up. Although in-place modeling we are talking, an account is shaping a mass, an account is shaping a wall! are two completely different things in revit, which have different functions.
We put it if your local model is a wall, not a mass!So the cover on the wall as we put it?
So let's summarize... I don't understand anything... .We put it if your local model is a wall, not a mass!
...because modeling with local mass a profile/scossine that follows a twisty path/tractor, not straight, could be, in my opinion, a way to get a cover that decorates a facade as, being the walls edited in the profile, it is not possible to apply profiles/scosins or frames in other way... .I'm sorry. I don't understand anything. You left saying you're shaping a local mass
to say the truth....the walls (system families) edited in the profile are always existed, they are those (see image attached in the application presentation post) that should be covered by a profile/scosine/frameand now it turns out that you have walls (system families) edited in the profile? ?
....if not local mass as you do...... ?What about the local mass then? ?
right.... so let's go back to head, put a profile/scoss/frameHowever, you cannot apply wall extrusions on a wall with "modified" profile.
