piotta
I have a perplexity on a problem encountered in the use of the extrusion roof.
in the case in question design the profile to be extruded that is concave and recalls a large c, the roof is therefore a coating that envelops a covered lift; closing it below, above and on one side, leaving it open on the other.
1: the roof appears below, overturned, the stratigraphy places the layer that should be outside to the inside. This error does not occur if you design the only horizontal portion of the cover, once you turn the cover vertically and then horizontally r does not orientate the face to the outside
2: completed the operation and activated the comnado "vertical opening" the sw gives me irreversible error
Are there any solutions to overcome these two problems? or do I have to use a mass?
