extrusion to surface
  • Thread starter Thread starter sh4d3
sh4d3
Hello, everyone, here I am at the first problem. Sorry about banality, but I've never opened a cad program before 1 month ago and I'm a little tired of entering philosophy.
I would need to start a pipe perpendicular to another, from the lateral surface of the latter. with the extrude I can only do it from the axial plane of the first tube.. magic pocket? :
thanks to all, I leave you an image to understand better:)
Good morning to you.
you can extrude "up to surface" from the outside or cut later with the circular section of the intersected tube.
Great! Thank you very much, I did! :) But I had to do also a subtractive extrude for the hollow tube because with the fine etrude it starts from diameter 0.28 and I needed 0.20. Not bad.. :
Thanks again, mythical :d
the fact that you do not extrude with thickness 0.20 depends on the precision set.
probably use the program without setting anything in the config.pro.
ah.. is highly probable! I didn't touch anything about config, I just installed it:)
I'll see to myself, I guess there's something here on the forum. as soon as I have 5 minutes spray, thank you very kind :)
I opened the config.pro from the proe settings (I also found the pathfile, quiet :d ). What parameter do I have to change (english, the Italian can't put it, even if I haven't left so much)?
Yes, but it was already at 0.0012. It's in mm, isn't it? Anyway, I don't get back to it. .
edit: in the place where I was talking about diameters obviously were 2.8 and 2.0 mm, not 10 times less :d
uhm..now even with default accuracy makes me do it! (and I didn't start it as administrator, I got win7 32)
mysteries of windows or... or of proe :d thanks for the availability, in any case :)
