face blend nx7.5
  • Thread starter Thread starter Omen
Omen
Good morning, everyone!
I'm starting to get my hands on version nx7.5... and I immediately met a problem!
using the face blend command I can't make a radius between faces belonging to different body sheets. I explain better: in the command mask you can select two sets of faces that then nx will try to radiate, in version 6 the faces of a set could belong to different sheet body; while now if the faces selected in the same set belong to different sheet body it gives me error!:confused:
What's wrong? ... there will certainly be some flags that I have escaped!
Thank you all!
O
Thank you all!
O
try installing 7.5.1, with that working.
Perhaps it is a youth error of 7.5.:biggrin:
