family folder name
MARCOC
I see from the few answers that the topic "centre content" is not well known. .
andanto on the "family property" of any component of the center contonuti...in the front page "general" there is the set "family folder name"
that will be the name of the folder where in the center counties will save the components
when once you set up in the project the path of the library files.. I should find 2 levels of folders. .
when we open up I should find myself
in the "contetent center file" library section all folders at 1 level
In fact inventor creates an intermediate folder that calls "it-it" and in it saves all folders of families
Does qulcuno know where you set the name of that folder and how to delete it?
igo image for clarity
test with:
- application options
- file
- default content center file: here insert the path of the folder where you want it to be generated under it-it folder, and where automatically the components will be generated and retrieved from the content center.
Let me know!
Exactly. you can decide only where to create the it-it folder, but it must be created in any case
