family name nested between the properties
  • Thread starter Thread starter sariii
sariii
Good morning.
I ask you for help with the nested families. I created a family facade panel called "a" and inside it I inserted as nested a generic model family called "1". when I go to charge the family "a" in my project, I would like it to appear in the property table the name of the family "1" that is present in the family "a". I don't know if I was clear... in other words I have a continuous facade panel that has a certain glass inside with its own code. I would like to make the glass code appear in the project when selecting the continuous facade panel in which it is contained. Is this possible? thank you to those who will be so kind to answer me!
Good morning.
if someone interested, I solved in the following way: I created a si/no parameter called "glass name". to this I have tied with conditional formula a text... ie: if(glass name,"1","2"). In this way when I put the glass name on the parameter, the glass name appears to me, if I don't put the check, the glass name 2.
Okay. I read the question, but I didn't understand. I like to see you solved the problem.
