Fanuc transfer data 18t
  • Thread starter Thread starter Noemi Perozzi
Noemi Perozzi
Good day to all,
place this message because I have a data transfer problem. I have a 300lm puma lathe that mounts a fanuc18t. Since memory is limited now I need to transfer programs to the pc, looking on the internet I found this program called ncnet lite. The problem is that I can't transfer programs from the machine, I couldn't find any guide that explains it to me. How can I do that?
thank you very much in advance
No
hi we solved with cymcoedit and it works.
attention to the cable that if it is not its specific does not go bidirectionally.
The transmission channel is 0 and must be enabled in mdi.
channel 0 should be configured in the lathe specifying the transmission parameters and must be the same also on the program,
