feasibility sections
  • Thread starter Thread starter X3D
X3D
Good evening to all,
after several attempts and research on the forum, I write to ask you for help.
I have to do some feasibility sections.
the problem is that I have mathematicians and cgr.
whether I work in scketch3d environment (in this case the cgr do not dissect) or I do a section in the product save it and then the amount in the drawing environment, I find myself with unmanageable files or better are composed by broken lines not joined, cgr included and if I make an offset think for hours; I tried combining the lines and smoothing it works but you lose a lot of time.
Is there any quick tricks?
I have done many tests but all the methods used make me waste a lot of time.
to make you understand better, using ug nx, I do a section(jt including that correspond to cgr) even normal to a curve and I modify it without any problem by doing offset/trimmando curves etc....
Is it possible to do it with catia v5?
I hope I explained.
thanks to all in advance
x3d
