feature per spherical friction a profiled
  • Thread starter Thread starter cougarz
cougarz
I have to make a dig that simulates a fresata with spherical frieze. Is there a feature that simulates the removal of truciole in correspondence of the volume swept by the movement of a mill? a sort of sweep cut but in which instead of drawing the dsi section draws a solid (the cut in note)
no, there is no such feature.
you can only make a simulation of the movement of the spherical milling and generate the envelope solid of such milling that you can then use for cutting. but such solid will be faceted and not continuous.
Thank you, too. I solved by sweeping and then a feature of revolution on the starting and arrival plans of the sweep...but I hoped it was something dedicated.
What you ask is quite complex at the mathematical level and I think there are no cad 3d that can do so.
Bye.
