ceschi1959
as known sw and nx adopt the same 'motor' and that is parasolid. They tell me about different behaviors between the two cads in mirroring the features. The example is this: I have two identical parallelepipeds, I execute a fitting on both, I deform the opposite face in one case holding the edge below, in the other holding firm the edge above. I mirror the feature fitting and in the first case fails while in the second it works.
I ask some good soul to do this with sw to see if, with this cad, it works in both cases.
thank you in advance to those who will want to answer.
c.
c.
