fields in catia v5
  • Thread starter Thread starter Black_Baron
Black_Baron
Hello everyone
I have a problem with the sampling of the sections, in the sense that I have to do a catalog in for a customer who wants that instead of classical sampling,
the one with the tilted lines, there is the colored sampling.
for the moment I do it manually by going to replace the fields covered with the colored ones, but I hope there is a faster way.
You should create a library of personal materials with the replacement of samples.
if you do not create the library the only alternative is the use of the command finds with the word "generated form*", after which through the command you can change the fields.
a warning.
if you have set English as a language of use of cat verification, you must check the name through the property panel (txdx on a plot, property in the pop-up menu, panel " feature properties")
