claghe
Good evening,
I'm new and I don't know if it's the right section.
I use zwcad.
I need to create a block that creates a text string with different fields.
I created the fields, I recalled the fields in the mtest string and saved the block.
when I call the block, even setting the values of the fields, does not update the string and leaves me or the # or the default value.
Do you have any advice?
igo image of the result
I need everything to speed up the quotation of the needles.
I use zwcad.
I need everything to speed up the quotation of the needles.Thank you.
