file creator
MARCOC
Hello everyone
someone knows where solid goes to take the data that writes in "Saved by" not the name of the pc and not even the account name controlled windows
other question can you report the three data on the "personalized" tab and "configuration specifications"? ? ?1638009181590.png
or noticed something, if I change the windows username, the name in the solid file does not change
So where does he get that data?
Does anyone know?
maybe the microsoft account, which is different from the windows username. However you can create a property that refers to a drop-down menu with the names you want, so it does not risk fishing unwanted data
hi asblo...how do I create this property with drop down menu? Would you explain how to do it?
Yes thanks asblo..I do not know the tab builder, so I create a simple property that I turn it by hand and away
Thank you very much
Thank you very much
If you complete the property by hand I suggest you look at it, it is much faster in use than manual input. is very intuitive and easy to use.
