piersilvio
Hello, everyone. .
I have a problem I couldn't answer. I did a modal analysis on a structure in the wb environment and now I need to import the model into ansys classic as I have to consider a modeling with solid65+ drucker-prager and perform a non-linear analysis. Unfortunately I realized that the .dat file produced by wb and imported into classic has no volume, corners areas etc.. so I can not enter forces, vary the type and material set in wb.
which would lead to the solution?
