file formato step
clark85
I would have a question about the step format we use:
we have to produce beams with hea/ipe profile with holes and a new supplier has just told us that the .step format is an obsolete format.
sincerely we have always used this format as a universal format (we use solidworks) to export 3d files and therefore it is convenient to "semit" to various suppliers.
the question is very simple:
according to your experience the step format is obsolete or not? is he simply creating problems where they are not there?
other universal formats to be used if necessary?
Thank you very much
the neutral step format does not seem obsolete, indeed it seems to me one of the best and very used as an exchange format for 3d files.
There are also other neutral formats such as iges, sat, parasolid.
Probably the supplier meant something else. clarify.
in any case I would ask your supplier (talk with someone from the technical office directly) because it considers it obsolete and possibly that format would prefer.
Thank you very much
will be another one that has to sell jt files like the 2020 revolution . which is innovative and contains additional information is true. that it has not replaced, at the moment, the step or iges formats in the collaboration between companies with different formats, is equally true.
unless we talk about specific cases. i.e. the company x passed to a yz format of data exchange and all its suppliers with her.
