ABarangani
Hello.
in our company file management is as follows:
the solidedge program is installed on the employee's pc while lazoro folders of the axis files, part, sheets and drawings are on a server
Recently a migration of working files from the -003 server to the -009 server was made.
in these days we have noticed the following:
if the file of assembly (migrated on the new server) did not vibrate to the subparts work properly.
if the file is copied or moved to another folder (also only the upper one) loses all links of the files and tries to go to search the old server address.
Is there any setting that needs to be changed within solid edge to always point it to the new server?
Has it ever happened to others?
