file opening fails
Angelo2449
Hello everyone,
I'm going crazy trying to open a file. I always get the message.
> error: type of wrong topic: file nil
the name of the file, complete of the path is > d:\altprovvisori\lcfile.dat < that translated the autolisp fa > d:\\altprovvisori\\\lcfile.dat <.
if I enter the route directly:
Code:
(setq path "d:\\altprovvisori\\\\lcfile.dat")
everything works perfectly, if instead I derive the path through the clipboard of windows 10 :
Code:
 (setq path nil)
(runapp "c:\\autocadsupporto\\\\libertytre\\\inputpregeo.exe "c:\\\\\autocadsupporto\\\\\\\\inputpregeo.tkn" :vlax-true)
(while (= path nil)
(setq route (getcliptext))
(princ "\n")
(princ)
(princ route)
(princ "\n")
obtaining > d:\\\altprovvisori\\\\\lcfile.dat < appears the above error message and the operation fails.
I also entered the apics before and after > "d:\\\altprovvisori\\lcfile.dat" but the result is the same.
Sorry, but where do you open the file?
is runapp the opening call? I didn't find her in the lisp functions
thanks crystal I omitted the opening of the file:
Code:
(setq path nil)
(while (= path nil)
(princ "\n")
(princ)
(princ route)
(princ "\n")
(setq frd)
The results are these:
path > > > > d:\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
point of origin : error: type of wrong subject: file nil
I believe you are reporting that the file variable contains a type of data not consistent with the one required by the command, or that it is nil (non-existent)
These are the results obtained with the different options:
option 1 - inserting the file name to open (path) directly from the command bar
Code:
command: lcdraw
(setq filename)
complete path: d:\altprovvisori\lcfile.dat
filename >> > d:\altprovvisori\lcfile.dat
...... It works!!!!!! ! !
option 2 - insertion via external program - not apici - simple overturn bar
Code:
command: lcdraw
(setq filename (getcliptext))
; error: type of wrong subject: file
I
option 3 - insertion via external program - non apici - double overturn bar
Code:
command: lcdraw
filename > > > d:\\\altprovvisori\\\lcfile.dat
; error: type of wrong subject: file nil
option 4 - insertion via external program - with apici - double reverse bar
Code:
command: lcdraw
filename > > > d:\\\altprovvisori\\\lcfile.dat"
"d:\\altprovvisori\\\lcfile.dat"
option 5 - insertion via external program - with apici - simple overturn bar
Code:
command: lcdraw
filename > > > d:\altprovvisori\lcfile.dat"
"d:\altprovvisori\lcfile.dat"
I don't know what to invent anymore! ! !
I believe that the difficulty is in the "nature" of what lcdraw produces.
Is that a pure string?
the getcliptext function is not autolisp. Did you make it? What does it return?
I follow the story:
the application > inputpregeo.exe < transfer in the Windows 10 clipboard the name of the file to be opened complete of the path.
the function > (getcliptext) < returns the contents of the windows notes then the name of the file to be opened complete with the path.
Code:
 (defun getcliptext(/ html result)
(setq html (vlax-create object "htmlfile"))
(setq result (vlax-invoke (vlax-get (vlax-get html 'parentwindow) 'clipboarddata) 'getdata 'text'))
(vlax release object html)
result
I do not understand why if I insert the file name from the autocad command bar:
Code:
(setq filename)
everything works perfectly with the string > d:/altprovvisori/lcfile.dat <.
If I extract the same string from windows 10 notes, it does not work.
Code:
result :
and yet it is the same thing, the same stringa|
try to process the autolisp string.
a useless thing, of the type (setq stringa2 (strcat filename ""))
see if she treats her like a string
