filter on value
mir
Bye!
I have a series of pipes identified like this:1659826825430.webpCan I create a filter that only displays based on the mark or other fields like cod.wbs.num or other?
Okay, thank you. I understand the logic.
I only add that then pressing this:1659946700242.webpyou can create a fixed view on the set filter.
now I have a "small" problem: in a Confederate file (with several links to rvt file) I tried to create an abacus but does not plague the elements in the linked files ... advice?
ordunque 2 problems...
1. the select in the model does not work ....1659955099798.webpeven if selecting a line did not draw the button (beware that the selection is not editable as it appears to me if I create this abaco directly in the file concerned)
2. not all fields populate
according to me find everything but for example is not compiled column cod. wbs.numero (of a couple of files find these values but of others nothing)
