filter total liquid cooling engine
  • Thread starter Thread starter Hope1
Hope1
one of the radiators that we installed on an industrial internal combustion engine was drilled by excessive debris content in the cooling system - conclusion reached after X-ray.
we don't have time to clean up and inspect the plant and we were thinking of inserting a filtering unit into the radiator (it's good even if it gets clogged every day)
Many of the commercially refrigerated liquid filtration systems are partial filtration, i.e. there is a bypass and only a part of the liquid is filtered. we have other radiators connected to the same cooling system and we need a filtration unit that cleans 100% of the input flow. the cooling liquid is 50% glycol 50% water, temperature 30-90 degrees celsius and maximum pressure 2 bar.
I ask you if you have any solution, even just to buffer the problem.
Thank you all.
