check the options in the parameters. I'm in charge.swx 2010 sp.4
I am making tables on parts shaped by my client (first work "real" with swx).
I can't complete a welding cord using the "Final Treatment" function (see attachment), do I have to do it by hand?
You seem to have the same problem I have. I want the area where the cylinder goes in tangence with the plate to be filled.check the options in the parameters. I'm in charge.
swx 2010 sp 4
But why do you want to fill that space?You seem to have the same problem I have. I want the area where the cylinder goes in tangence with the plate to be filled.
a question of pure curiosity: Why don't the cord do it in the model, where the filling would be correct?swx 2010 sp.4
I don't remember anymore.a question of pure curiosity: Why don't the cord do it in the model, where the filling would be correct?
the final treatment "fills" the area between the 2 selected lines (until the apparent intersection). there in the inside you have a third line, clear that it remains excluded from the selection.swx 2010 sp.4
...I can't complete a welding cord using the "final treatment" function (see attachment), do I have to do it by hand?
Is there no final treatment or the caterpillar in the tables?swx 2010 sp.4
They are models that gave me the client, I just have to make the table.a question of pure curiosity: Why don't the cord do it in the model, where the filling would be correct?
no in fact, I don't know if in recent versions they put it, you know that I am always 12 releases back.Is there no final treatment or the caterpillar in the tables?
I think it's a pass on, right?
:tongue::
Marco:smile:
This doesn't work well, in the sense that when I go to do the sampling of the inner part comes out a gushing medium, however I am sure I have not yet understood how the command works. But in the end, it's not that important. I just thought I didn't understand how to use the command.first with inner line and circle (as above), ok. then with outer line and circle. the 2 fields overlap and see only one as you wish.
1) I think I understand what you say: a pipe industry is blacked out or in any case a "strange" area1) this does not work well, in the sense that when I go to do the sampling of the inner part comes out a medium gushing, however I am sure I have not yet understood how the command works. But in the end, it's not that important. I just thought I didn't understand how to use the command.
2) Of course, but to put a diameter stake on a circle in the plant, he first puts the radius, then I have to say that no, look that I want the diameter, then finally I have to tell him that I want both terminators because on the diameter quota it takes two, I just told you to put the diameter, not the radius, do not pretend to have understood and as usual do the things half.... :biggrin:![]()
Well, this is normal and also in swx. both in part (multibody:biggrinWelding cords can be made in 3d, with the special "weldment" environment.
..and if you refer to that section that you attached, in that floor passes the hole that also crosses the wall of the pipe.But to put a diameter stake on a circle in the plant, he first puts the radius, then I have to say that no, look that I want the diameter, then finally I have to tell him that I want both the terminators because on the diameter quota it takes two, I just told you to put the diameter, not the radius, do not pretend you did not understand and as usual do the things halfway... .
the way + fast to make that quota is:..and if you refer to that section that you attached, in that floor passes the hole that also crosses the wall of the pipe.
as I told you before that is no longer a continuous circle and the automatic quota indicates the radius by default because you are measuring an arc.
if you imported the quotas from the model you would have the diameter (if in the sketch you assigned the diameter).
Marco:smile:
Okay, all clear, it's just that the length of the welding was fixed at 5 mm and it didn't come to fill all the space, I lost myself in the classic water bicker. thanks anyway for the indication!1) I think I understand what you say: a pipe industry is blacked out or in any case a "strange" area
you have to do the third clik "in the void" by moving the mouse to the direction where you want the black triangle to appear. prove that taking your hand is automatic.
