finestre apertura file ccon memoria
  • Thread starter Thread starter Tarkus
Tarkus
Hello everyone,:smile:
I don't know if this mine goes here or more generally in the windows section, but...
to open a file, I must indicate the path to find the folder where the file is located.
If later, I open another file, the "open" dialog box is already placed on the folder where I opened the last file.
But this does not happen on all commands, e.g., saving copy by name does not maintain the position.
not to mention the design assistant, where if you want to copy with new name in other file folder, every time you have to untie to tell him where to go.
However, apart from all this avalanche of words :36_3_4: which I wrote, how do you make "remember" the last position at the path windows? :biggrin:
that I know is so, and so remains. You can make some kind of indexes working within the projects you create. Of course, if you save out of the project... it keeps what you did or the base of the path. the logia is always the same if you look good.
