finestre archicad problem
  • Thread starter Thread starter juli
juli
Hi... I have a problem with windows in archicad... I managed to make them while those on the upper floor didn't and I can't understand why... ..it doesn't let me do them and tells me to put the point on the wall I click on the wall and it doesn't give me anything and it keeps telling me the same thing.....
(I'll give you the prospect in 2d of what I have to do)
missing the annex, however do not attach the prospectus 2d attach the screen of the floor where you cannot put the windows
You had to warn me first! I was not prepared to see archicad with black background:
apart from the jokes, the walls are continuous, or did you draw them by interrupting where there are openings?
What are those green and white elements?
the barrel vault is only represented in lines, so the brown one is the loft, or is it the time? or a retino?
..I lost a life for ste windows and then a nice copy glued with those of the downstairs and viaaaa :biggrin:...no comment... I know....discussed if I made you waste time....:redface:
Thank you very much. .
